Sillcock parts
Old 10-11-16, 10:01 PM
O
Received 1 Upvote on 1 Post
Sillcock parts
My outside slllcock leaks from the vacuum valve. I have been to Lowe's, Home Depot and a plumbing supply store with no luck getting a replacement. The ones I have tried are to large to thread in. Name:  IMG_8421.jpg
Size:  27.9 KBName:  IMG_8422.jpg
Size:  25.4 KBName:  IMG_8424.jpg
Any ideas would be appreciated
Old 10-12-16, 05:36 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
If you can't find the parts I would just replace sillcock. You have spent more time trying to find parts than time to replace.
Old 10-12-16, 05:49 AM
P
Received 2,009 Upvotes on 1,801 Posts
If you replace your spigot one of my favorites is made by Woodford. It has a high flow rate, is quite reliable as far as not leaking and it's easily repairable. Lowes used to carry them long ago but now you'll have to find another source like online or your local plumbing supplier.
Old 10-12-16, 08:26 AM
O
Thanks for the suggestion, I wanted to find the parts first because they put the sillcock on the corner of the house and I would have to remove some of the siding to get to it. I don't want to try to unscrew it without seeing how it's attached. Maybe I can find a plug to cap it off.
Old 10-25-16, 10:43 AM
O
Applied my own fix. Easiest fix
Old 10-25-16, 12:37 PM
P
You no longer have the anti-sipon feature so make extra certain that you unhook your hose before winter. Also, when it comes time to sell your house a inspector may pick up on the hack and note that it does not comply with code.
Old 10-25-16, 04:10 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Its a merrill select..
Please call the manufacturer to verify.. And get parts..
https://www.merrillmfg.com/product/m...of-wall-faucet
Old 10-27-16, 05:06 PM
O
Please explain, if the outlet is shut off inside the wall how does the water get siphoned past it?
I'm having a senior moment, thanks
Old 10-27-16, 05:19 PM
pugsl's Avatar
The shut off is on a long stem and shuts off in wall. With hose off or hose on ground water will drain out of exterior part of valve That is where the anti siphon part comes in. Anti siphon will open and valve will drain.
Old 10-27-16, 08:09 PM
lawrosa's Avatar
Super Moderator
It does not...
Only if you left you faucet on say for watering the garden. Then the town came by and shut off the water to your street and your house.
If the hose was left on the ground and in a puddle of water then there could be a siphon effect. The water in the puddle will come back up the hose and into your drinking water ..
The anti siphon valve eliminates it...
