Faucet lines are too short
Old 10-19-16, 07:59 AM
P
My wife bought a faucet from IKEA which has water lines which I think are permanently attached to the faucet. There certainly isn't any way to tell. Even if they aren't, it is a pain in the arse trying to deal with IKEA, and, in any case, I would rather not mess with them. And I really don't want to spend the time to alter the existing piping. It there any problem with me putting something in place to extend the faucet's water lines? What would would be the way to do it?
Old 10-19-16, 08:32 AM
ray2047's Avatar
Post a picture of the faucet and the ends of the lines. You should be able to extend them with new supply lines or connect to your existing supply lines but we need to know if they are ½" male pipe thread or what. http://www.doityourself.com/forum/li...rt-images.html
Old 10-19-16, 11:56 AM
H
Received 8 Upvotes on 7 Posts
As Ray said, you should be able to easily extend supply lines. Having said that, after a couple experiences with IKEA plumbing stuff, I would stick to furniture.
Old 10-19-16, 12:57 PM
F
A few years ago I installed a new kitchen faucet for a friend. The attached piping on the faucet was not long enough to reach the shut-off valves so I had to add regular flexible hoses made for faucet installations. To couple the new hoses and the faucet hoses I had to use standard 3/8 inch compression unions, throwing away the nuts and ferrules and only using the union body.
Old 10-19-16, 01:13 PM
P
Here are pictures. The ends of the hoses connect perfectly to my 3/8" valves. I just wish they were about 8 inches longer.
Old 10-19-16, 01:28 PM
Received 125 Upvotes on 110 Posts
Take the faucet to any box store to see what size lines will connect to what you have.
Find one that matches the tread but too long then just make a simple loop with the flex line.
I have to agree, there's been hundreds of post about the plumbing and electrical issues coming from Ikea.
That would have been one of the last items I would have bought from them, where do you plan on finding parts for it?
If it was mine I would return it and buy a Moen so I can find parts.
Old 10-19-16, 01:30 PM
F
Go to the homecenter and buy two 3/8 inch brass compression unions and follow my instructions in post #4.
Sioux Chief 3/8 in. x 3/8 in. Lead-Free Brass Compression x Compression Union with Insert-909-121001 - The Home Depot
Old 10-19-16, 01:49 PM
That sure looks bigger then 3/8.
May need this one, only way to know what it is and if it fits is to do as I suggested and take it with you.
Sioux Chief 1/2 in. x 3/8 in. Brass Female Compression x Compression Adapter-909-47161001 - The Home Depot
Old 10-19-16, 02:07 PM
F
Doesn't look big enough to be 1/2 inch. It could be some crazy European Metric thread for all I know.
I wholeheartedly agree with returning that faucet and buying a Moen.
Old 10-19-16, 04:25 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
The correct method would be using 2 delta supplies as extensions.. ( Thats what they were called in the 80's as only delta made them..)
Im sure they may make a flexible version... Not sure...
BrassCraft 3/8 in. O.D. x 12 in. Copper Faucet Riser with 3/8 in. O.D. Compression Nosepiece in Chrome-1-12KC C - The Home Depot
Old 10-20-16, 09:18 AM
G
Received 1 Upvote on 1 Post
Mike those extensions are getting hard to find in stores. I wanted to use them under a pedestal sink recently because the pedestal wouldn't hide the plumbing and I didn't want to cobble together the supply using brass compression connectors. Finally found the extensions at the largest/oldest/best plumbing supply in the county and they had them stashed in the back store room. If I hadn't lucked into a grizzled old counter guy to help me I still would be looking. Even your Home Depot link was for online-only.
Old 10-20-16, 10:10 AM
Handyone's Avatar
The Delta type extensions are very hard to find, Lowe's is the only store I know that carries them (in store only) and I live in a large city.
Here's a link:
https://www.lowes.com/pd/Homewerks-W...ine/1000011658
The specs on the Lowes site are incorrect, it says 3/8 x 1/2. This line is 3/8" male compression by 3/8" female compression and I always keep a few on hand.
Like Furd said, the unions will work, but it's nice to keep fittings to a minimum if possible.
Old 10-20-16, 10:27 AM
P
Well, I took the long way around on this one. I found 3/8 to1/4 and 3/8 to 3/8 unions at Home Depot, but not supply lines that would work as an extension. Then, stupid me, I realized that I have PEX piping that I can very easily extend. The IKEA faucet has a 10-year warranty, so it's not worth the hassle to return it. But I do have another plumbing issue that I'll post.
Thanks for all the help, guys and gals.
Old 10-20-16, 11:16 AM
Received 1,197 Upvotes on 1,152 Posts
Moen is warranted for life.
Just saying.
Old 10-21-16, 07:07 AM
P
I know. I have always used Moen faucets, and their warranty service is excellent. I don't have time right now to go through the return process and shop for a new faucet.
