Slightly crooked drain line needs to be straightened
Old 10-20-16, 10:50 AM
My bathroom plumbing rough-in was done a few months ago, and now my wife has chosen a bathroom vanity that has drawers which are full width but don't go all the way back to the wall. Everything would be fine except for the fact that the 2" PVC drain line, which comes up through the floor, slants outward from the wall and at the top is about half an inch too far from the wall, so that the bottom drawer doesn't close all the way. I'm wondering if I should just cut it off near the floor and come down to it with stuff from the sink or cut it off near the floor and find a way to add a section of 2" PVC that would come straight upward. Which would cost me more trips the Home Depot to get the pieces I need?
Old 10-20-16, 10:55 AM
Received 118 Votes on 105 Posts
pics could be helpful
Another option would be to shorten the depth of the drawer.
Old 10-20-16, 12:15 PM
Handyone's Avatar
It should be fairly easy to adjust the angle of the pipe slightly by using a glued coupler or a no-hub coupler (no-hub is less adjustable of the two).
I wouldn't cut the pipe at the floor. I would bring the pipe into the cabinet and make any connections behind the bottom drawer.
Leave about 1-1/2" of stub out above the vanity deck, more if possible.
Old 10-21-16, 07:19 AM
Here is a picture. The pipe is 14" long, and the top is 1.2" further out from the wall than the bottom is. The bottom of the lower vanity drawer is 6.25" above the floor.
Old 10-21-16, 07:54 AM
Handyone's Avatar
This is pretty severe. Will two 22.5 elbows work?
You would cut the pipe low. The pipe will still go up at an angle.
The angle can be reduced and the pipe placed closer to the wall by adjusting the elbows.
Shortening the drawer is the only other option I see.
ray2047's Avatar
Received 13 Votes on 11 Posts
You have a problem if the drain is coming through the bottom instead of the wall. Through the bottom use to use "S" traps but that isn't code compliant anymore. You will need extra work to get it to work with a "P" trap.
HTML code is On
