Shutoff supply valve
We're getting a new fridge through Costco. Free delivery, installation, removal. But, the installation company requires a shutoff valve behind the fridge. current valve is in basement with a flex copper line that comes up to the current fridge. Can I cut the flex copper and install another shutoff using a compression fitting? wise? unwise? do they even make such a valve/fitting? Thanks!
Yes, you can. But I'm surprised they require a valve at the appliance itself. Must be a new code. I would suggest replacing that copper line with poly tubing. Easier to rout and put into place. Be sure to use the brass inserts if you go plastic.
Most appliance sellers require a valve behind the fridge now. It's not because of code, it's because the installers are not authorized to adapt any home plumbing, and might refuse to hook up the ice line.
I would install a 1/4" compression valve behind the fridge, brass or push in plastic will work. Push in plastic valves (John Guest fittings) are compatible with 1/4" copper.
Eventually, I would recommend you install an ice maker box in the wall.
Just for info, a saddle valve might void your warranty.
I doubt if you will have any problems if the water dispenser is working fine, but the manufacturers state that a full port valve must be used in order for the solenoid valve to work properly.
