Is this a double fixture fitting?
Old 11-07-16, 12:15 PM
F
Hi,
I'm looking for a double fixture fitting (cross) here in Toronto. Below is what my local plumbing supply offered, is this a double fixture fitting or a double San tee?
Thanks
Old 11-07-16, 06:15 PM
ray2047's Avatar
Tell us what you are going to use it for. Is it something like this http://www.doityourself.com/forum/pl...hat-drain.html or something else.
Old 11-08-16, 05:24 AM
F
Exactly, it's for washing machine/utility sink drains. You can see my original thread here:
http://www.doityourself.com/forum/pl...her-drain.html
The top will vent to an AAV. I intended to have 2" all around, but I think this will work with 1.5" for the sink/washer. I just wasn't sure if the bends were the correct shape.
Old 11-08-16, 05:40 AM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
You will not be able to see through or stick a wire (side to side) through a double fixture fitting because of the longer bend and baffle. (That is the type of fixture you want) A double san tee is only for venting and can cause problems when used as a double fixture. Can't tell which yours is without looking inside it.
