Washer drain into stack above toilet connection
I have a laundry room that was created from an old bedroom.
Currently the washer drains into the laundry sink, but I getting stackable units which will be on the opposite side of the sink and then installing cabinets between the units and the sink.
The wall behind where the units will go has a stack that goes from the basement to the roof. Attached into this stack below the main level (in the basement) is a toilet.
Attached on the main level through a wye are vents for the laundry sink and toilet in the basement.
Can I put a wye above where the toilet connects to hook the trap of the laundry stack into?
Thanks
Thanks
