Dishwasher hookup
Old 11-22-16, 09:32 PM
K
Dishwasher hookup
I am replacing the drain pipes for my kitchen sink. They are currently 1 1/4" and replacing them with 1 1/2''. My problem is with the dishwasher connection. It is currently cut to the 3/4" size. Is this the standard size for the Y branch on the tailpiece? If is is not will I need to replace the hose or is there an adapter?
Old 11-23-16, 03:08 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Your kitchen sink should have had 1 1/2" drains to begin with. You should be able to put the 3/4" tubing on the slanted barbed fitting with no problem.
Old 11-23-16, 04:49 AM
Handyone's Avatar
If the drain doesn't fit the branch tailpiece, here's an adapter designed to repair a cut drain hose:
InSinkErator Dishwasher Connector Kit for InSinkErator Garbage Disposals-DWC-00 - The Home Depot
If you have a garbage disposal, the 3/4" hose should be attached to that. Be sure to knock out the disposal inlet plug.
Old 11-23-16, 02:46 PM
K
Well it wasn't me who put in the 1 1/4".
How it looked before
Attachment 73447
How it looks after
Attachment 73448
Old 11-23-16, 05:41 PM
chandler's Avatar
Old 11-23-16, 11:22 PM
K
I did follow those instructions - not sure why they didn't show up. They show up when I preview the post
Old 11-23-16, 11:26 PM
K
lets try it again
before
after
Old 11-24-16, 03:58 AM
chandler's Avatar
The second picture, I assume is an "after" picture. It seems to be connected properly. Did you use an adapter or were you able to connect the DW with the existing fitting?
Old 11-24-16, 08:41 AM
Handyone's Avatar
Good Job
Looks professional. Technically your old drain pipes were 1-1/2" slip tube.
The slip tube usually doesn't cause any problems, but your new 1-1/2" ABS is better and has a larger inside diameter.
I'm curious as to what was the problem with the old pipes. From what I can tell both sink bowls should have drained fine.
PS: I have extra turkey if you need it
Old 11-25-16, 10:02 PM
K
For the dishwasher I was able to find an adapter at the Wye Connection for the 3/4" tube that I had.
The problem with the old pipe's was it was leaking. The mail problem I could find was that the tailpiece was not that deep into the connector and the seals might not have been good anymore either. Didn't take much of a touch though to pop the tailpiece out of the drain.
