Sealing sump pump PVC discharge pipe
Old 11-26-16, 08:03 PM
B
Today I had to repair my sump pump discharge pipe. I don't know what the grey stuff was that removed. My house was built in the late 80's and has aluminum siding. Can someone recommend what I should use to seal the area around the PVC pipe on the exterior of my house? Thanks in advance.
Old 11-26-16, 09:34 PM
Received 125 Upvotes on 110 Posts
Not sure how you expect us to suggest how to repair what we can not see.
Post a picture please.
Old 11-27-16, 04:44 AM
Marq1's Avatar
Received 1,138 Upvotes on 1,032 Posts
More than likely it was a putty material used to fill gaps around plumbing and electrical pipes. Comes in a small brick and can be found at any of the big bx/hardware stores!
Old 11-27-16, 08:04 AM
B
Thanks guys. Here is a photo. I think this is what I am looking for. I just have to figure out how to remove the remaining residue.
Old 11-27-16, 09:24 AM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
Can't tell from picture if it is hard but it should just chip off with a screwdriver or chisel.
Old 11-27-16, 10:02 AM
Received 3,485 Upvotes on 3,128 Posts
You could use WD-40 or mineral spirits to remove the left behind residue after scraping.
Your link to duct seal is the correct product.
Old 11-27-16, 12:35 PM
B
Great. Thanks for the tips guys.
Old 11-27-16, 03:18 PM
B
Ok guys, I didn't have any WD40 or mineral spirits so I tried goo gone. It didn't work nor did scraping it. You all think it would be safe to just go over it with the duct seal?
