Very Noisy Tap!
Old 11-30-16, 08:05 AM
Very Noisy Tap!
Whenever i run my basin tap in my upstairs bathroom it makes a really loud noise, unless it's running full power. I thought it would be trapped air but surely that can't be every time can it? any advice would be appreciated!
Old 11-30-16, 12:11 PM
Handyone's Avatar
I would change the angle stops (valves) coming out of the wall and the faucet supply lines. Old washers inside the valve can disintegrate and block the flow of water.
Restricted flow, especially through a valve, can cause noise and shaking of pipes.
The same could apply to your faucet valves, they might be restricted and need replacing.
Old 11-30-16, 11:37 PM
steve_gro's Avatar
Received 1 Upvote on 1 Post
I agree with handyone -- sounds like a loose washer which can make a huge racket.
I'd start at the faucet, which is a little easier than repairing/replacing angle stops.
Old 12-06-16, 02:31 AM
Thanks handyone I'm not quite sure what you mean by angle stops would you mind sending a photo or a link?
Old 12-06-16, 05:08 AM
Handyone's Avatar
Here's a stop:
This is 1/2" nominal compression inlet (for use on copper) and is the most popular type.
Your house pipe might also be 1/2" pipe threads.
BrassCraft 1/2 in. Nominal Compression Inlet x 3/8 in. O.D. Compression Outlet 1/4-Turn Angle Valve-G2CR19X C1 - The Home Depot
Old 12-06-16, 06:12 AM
Thanks very much, I live in the UK so I'll have a look online for some low delivery cost options. I'm not the most handy but I'm not a complete stranger to a bit of handy work (more of a computer geek)... would I be better getting a professional after all or would it be an easy DIY after a couple of online tutorials?
Old 12-06-16, 07:00 AM
Handyone's Avatar
The best thing to do is post a picture of the valve, here's a link:
http://www.doityourself.com/forum/el...-pictures.html
A picture will show the level of difficulty.
Old 05-17-17, 02:09 AM
Thanks!
Hey everyone, just wanted to say thanks for all your help, I'd actually forgotten I'd written this post and the problem was still driving me mad! A friend of mine recommended fitting this isolating valve https://www.drainagecentral.co.uk/Pl...solating-Valve , which is actually plastic, but it seems to have done the trick.
