How would you cap DW water line?
Old 12-11-16, 06:46 AM
C
Hello all!
Removing old dishwasher, how would you cap off copper water line temporarily, if you needed time before installing new DW?
Name:  dishwasher valve.jpg
Old 12-11-16, 06:56 AM
Received 126 Upvotes on 111 Posts
Follow the line back under the sink, there should be a shut off for it, no cap needed.
If it's a saddle valve, your better off replacing it with a 1/4 turn valve.
Saddle valve tend to leak and plug up, not even legal in some areas.
Old 12-11-16, 06:57 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Old 12-11-16, 07:21 AM
C
Thanks!
Following the line back under the sink, it appears to lead to a blue spigot valve similar to what I see on the outside of my house, for the garden hose.
Name:  dishwasher valve2.jpg
Old 12-11-16, 07:31 AM
Handyone's Avatar
Remove the DW line from the valve adapter, it's 3/8" compression. Use two wrenches.
IF the valve doesn't shut off completely cap the compression outlet off.
Use a 3/8" compression cap with a ferrule inside (compression ring).
Also put a little pipe dope on the compression threads.
I recommend you connect the new DW with a braided flex line.
Old 12-11-16, 07:48 AM
C
Originally Posted by chandler
With a 1/2" brass plug and Rector T thread sealant. Sioux Chief 1/2 in. Lead-Free Brass Square-Head Plug-930-502001 - The Home Depot
Thanks!
Where does this go?
Old 12-11-16, 07:52 AM
C
Attachment 74295
Thanks!
The new DW comes with this 5-ft 125-PSI Stainless Steel Dishwasher Connector:
https://www.lowes.com/pd/EASTMAN-5-f...nector/3190279
Old 12-11-16, 08:27 AM
Handyone's Avatar
That's a good kit. Let us know if you need help connecting the new unit.
The important thing is try to keep the existing valve if possible.
If it leaks a little after closing, cap it off and check for leaks.
Don't use the compression cap without a ferrule inside, it will leak.
Old 12-15-16, 12:53 PM
C
Thanks!
FWIW: I closed the valve and ran a "quick rinse" cycle (10 min) test...No leak at the valve. However, I did feel moisture, where copper water line connected to DW. Please keep in mind, I need old DW unhooked for extended period of time before installing new DW, during which time I don't want to keep my whole house shut off.
Copper water line connected to DW, where I felt moisture
[ATTACH=CONFIG]74454[/ATTACH]
Old 12-15-16, 01:21 PM
Handyone's Avatar
When I said check for a leak at the valve, that meant with the 3/8" tubing removed from the valve.
The valve might not leak at all, but you need to be prepared in case it does. Valves fail.
- Place towels and a drip pan under the valve, then close the valve
- Open the kitchen faucet to hot and keep it open until done
- Slowly loosen the 3/8" tube nut. Water will come out.
- You should know quickly if this water is under pressure (meaning your valve has failed) or just draining out
Let the valve drain, assuming it's good.
If it drips a little after draining seal off the outlet with the compression cap and ferrule.
Old 12-28-16, 04:05 PM
C
Thanks!
I haven't had a chance to check for a leak, yet but... That said, since, I don't have soldering skills, how about replacing the saddle valve with this?
Name:  dishwasher valve-new.jpg
Old 12-30-16, 08:36 AM
C
FWIW: Until I get back to this location, here are a couple of better pics of the blue valve, I took a while back:
Name:  dishwasher valve3.jpg
Name:  dishwasher valve3cu.jpg
