Sizing water pipes to and from hot water tank
Hi guys!
I am running new pipes in the basement before I close all walls with drywall.
Right now I have the following set up:
5/8 copper service to a 5/8 water meter, down to 1/2 copper after the meter, and then 1/2 pex to hot water tank and 1/2 from hot water tank.
I have 2 full bathrooms, 2 kitchens and 2 washing machines.
My plan is to run 3/4 pex after the water meter, with two 1/2 take offs from the cold pipe to different fixtures, to the water tank. Also, run a 3/4 hot water pipe to the 2 nearest 1/2 take offs to fixtures. Btw, by local code (Ottawa, Ontario), I have to have a hot water mixing valve installed.
Or should I just run 3/4 cold to the water heater, and then just go with 1/2 pex from there?
What do you think?
Thanks!
What do you think?
Thanks!
I'd run 3/4" pipe for all your main lines. Branch off to the various fixtures/rooms in 1/2", and when you get to your last branch, branch both as 1/2". Keep it simple, but make sure you have enough volume everywhere you need it!
I run 3/4" PEX trunk lines and come off with 1/2" to feed each fixture. 3/4" x 3/4" x 1/2" T fittings make the job really easy and you have good flow to all your fixtures.
Thank you for your responses.
Yes, the house is 60s construction so the service pipe is 5/8 copper, they don't even sell those anymore. This is why I would like to expand to 3/4 pex because the inside diameter of 3/4 pex pipe and fittings is close to the inside diameter of 5/8 copper.
So what I will do is run 3/4 pex after the water meter, with 2 main 1/2 " take offs before the 3/4 cold pipe reaches the HWT, then run 3/4 of hot pipe to the nearest 1/2" takeoffs to two bathrooms, kitchen sinks and washers.
