Bathroom Vanity plumbing does not lineup
Old 04-19-17, 09:47 PM
Received 1 Upvote on 1 Post
Please advise. Old bathroom had 48 inch vanity with dual sink. When we remodeled thought we will get same but then it was too expensive. So we got 2 30 inch vanity. Now the problem is that the plumbing is not lined up. According to code we cannot use the flexible drain pipe under sink. Don't want to cut the vanity drawer. Is there any other ideas. See pictures
Last edited by ray2047; 04-19-17 at 11:22 PM. Reason: Rotate, crop, enlarge, and separate images.
Old 04-20-17, 07:20 AM
Handyone's Avatar
Something like this might work:
The elbow attached to the wall is an Ace 44489 1-1/2 IPS cast brass elbow.
You could also shorten the pipe coming from the wall and use a 1-1/2 x 1-1/4 slip tube flexible rubber coupling.
