Factory wax ring -- good to use or buy a better/thicker one?
Old 04-23-17, 07:04 PM
T
hello.
i bought a new toilet and it comes with a wax ring.
The factory wax ring seems to be a bit thiner - should i use it or buy a new one, which is much thicker?
Does thinner means less life expectancy? This is not something i would like to replace often so i want to get it right.
thanks
Old 04-23-17, 07:14 PM
Received 3,479 Upvotes on 3,124 Posts
For the price of a wax ring I'd buy a better one.
Thinner doesn't mean shorter life but if too thin it may not seal properly.
Old 04-24-17, 07:51 AM
Received 1,197 Upvotes on 1,152 Posts
I think after you've set a few toilets you understand how much 'squish' you should get out of the wax ring. As long as you get that amount, I would be fine with the ring provided. That said, if you're aware of any reason ahead of time that you might need a thicker ring than usual, then I would not attempt the one provided.
Old 04-24-17, 09:50 AM
Z
Received 372 Upvotes on 332 Posts
I usually splurge and go for the wax ring with the rubber gasket. Just another level of safety for future leaks for an extra dollar or so.
[ATTACH=CONFIG]79990[/ATTACH]
