Outside pvc pipe leaking
Old 06-15-17, 07:09 PM
Outside of my basement I have two pvc pipes side by side. One is pressure relief for the hot water heater. The other is tied to the houses cold water supply. There is a fitting between the house water supply and the leaking pipe. This is not connected to the A/C drain system. I have a picture that might help. The hot water heater is 12 years old if that makes a difference. Thanks in advance for any help you can provide.
Old 06-15-17, 07:22 PM
Received 3,485 Upvotes on 3,128 Posts
Welcome to the forums.
That looks like a PRV (pressure reducing valve). It should say it on it.
That reduces the incoming water pressure to a lower usable level.
If that is definitely the leaking pipe then it may need to be replaced.
Since this is like a one way valve..... it requires a pressure tank to be on the water heater. Otherwise when the water heater heats the water and it expands.... it can be forced out of unexpected places.
Old 06-15-17, 07:25 PM
P
If it's the drain from the heater then you'll need a new t&p valve or a new heater because something is wrong
