How to remove pipe fittings from unstable pipes?
Old 07-16-17, 02:30 PM
How should I secure it to be able to apply some torque? Please don't laugh. Thanks!
http://img-cdn.filefactory.com/embed...uo9ns635hd.jpg
Edit: I think I just got it. A pipe wrench! Let's see....
Old 07-16-17, 02:48 PM
Received 3,748 Upvotes on 3,361 Posts
A pipe wrench or adjustable wrench.
Old 07-16-17, 03:12 PM
XSleeper's Avatar
Received 1,839 Upvotes on 1,654 Posts
If you put a large visegrips onto the body, you will have something to hold onto while you use a wrench to loosen your parts.
Old 07-16-17, 03:32 PM
Okay, I'm back up to speed. I'd forgotten how I'd done this a couple times before but now I'm here:
http://img-cdn.filefactory.com/embed...pjaw1f7q9x.jpg
As u can see I've got this shark bite thing that is supposed to remove these ferrules. Will it? Just watched a couple of videos that made it seem easy but I'm not moving anything with this tool. What's the trick here? The ferrule isn't exposed in the back so I can't push directly on it but the nut itself yes. Maybe I can't use the tool like this? Thanks so far...
Old 07-16-17, 04:04 PM
R
Received 67 Upvotes on 52 Posts
I don't think that is a shark bite fitting.
Old 07-16-17, 04:08 PM
G
Received 2 Upvotes on 2 Posts
That does not look like a shark bite fitting to me,more like a compression fitting there. Might have to cut it off.
Old 07-16-17, 04:31 PM
Oh, I thought that orange tool I have is supposed to remove that ferrule.
http://img-cdn.filefactory.com/embed...xfoiqiwlxp.jpg
This is insane. Why couldn't this have been a nice easy job? I'm having to cut underneath this faucet part with one of these multi cutting tools because the nuts underneath are rusted. If I have to replace the whole sink I'll have to remove the garbage disposal and this will take longer.
Anyone know how I can temporarily cover the pipes below while I work on this and still have water? Are there temporary covers or something? I'm only familiar with one shutoff valve outside for the whole house.
Old 07-16-17, 05:02 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
They have compression fitting shut off valves. All you have to do it take old one off. Nut should loosen with a sharp tap with a hammer on wrench. Be sure you are holding old valve before you tap wrench. Here are some valves.
https://www.lowes.com/search?searchT...tting+shut+off
Old 07-16-17, 05:10 PM
Thank u. Silly me. I already have my valves but it just didn't occur to me I could install them by themselves and they could cut off the water. But I got the faucet off and just need to drill a hole in the sink for the veggie sprayer. I should probably buff the area I ruined.
http://img-cdn.filefactory.com/embed...rgx2g3mnxz.jpg
Are these compression valves easy to install? I did it once a while back. Don't remember if it was easy? I know sawing off those old ferrules won't be!
Old 07-16-17, 05:17 PM
Compression valves are a standard size meaning that your existing nut and ferrule should work with a new same size valve.
At the very least.... the new valves come with a ferrule and nut if you did have to replace them.
You would cut the pipe cleanly just behind the ferrule. Trying to cut a ferrule off usually damages the pipe and a new ferrule won't seal properly.
Old 07-16-17, 05:56 PM
K thanks. I'll just leave them then. Just screw them on? Do I need to do anything to set the ferrule right or something? Can you screw this part up?
I have a tendency to mess things up.
Old 07-17-17, 04:15 AM
pugsl's Avatar
Just slip the valve on the pipe. Be careful not to cross thread nut.
