Best tool to remove these sewer inspection plugs?
Old 08-14-17, 07:09 PM
A
I think these are 3 inches in diameter. There is a bit of paint over them so need to apply some force. Is there any kind of a special tool for this style? What is this style called?
Thank you!
Old 08-14-17, 11:01 PM
steve_gro's Avatar
Received 1 Upvote on 1 Post
I would use anything that happens to fit the slot, but Pasco makes this multi tool:
https://www.amazon.com/Pasco-Cleanou.../dp/B000PSFT80
I'm curious why there would be 6 plugs all in the same area.
Old 08-15-17, 04:47 AM
P
Received 1,849 Upvotes on 1,655 Posts
I have a metal fabrication shop and have lots of pieces of scrap laying around. I would find a piece of metal close to the thickness of the slot and cut it to be just a bit shorter in length than the slot. Insert it into the slot then grab and turn it with a large Crescent or Pipe wrench. If I wanted to make a permanent tool I would weld a 3' long piece of pipe to it to make a handle. If you don't have scrap metals lying around a metal fabrication or welding shop could easily make it for you.
Old 09-01-17, 04:24 AM
Steve Logan's Avatar
Anything that fits the slot that is long and robust enough to get a set of mole grips round for leverage. I used to work on the rigs and do this sort of thing when 'conventional' methods would not work!
