Clean with brush or abrasive?
Old 09-04-17, 08:20 AM
G
Received 1 Upvote on 1 Post
I've always used a brush instead of crocus cloth. Any reason i should try the grit instead?
Does the cloth leave a smoother or cleaner surface for soldering or compression ferrules?
Old 09-04-17, 09:12 AM
Marq1's Avatar
Received 1,137 Upvotes on 1,031 Posts
Ive always used plumbers sand cloth so I guess it's always worked for me, not that I can say it was the cause of any known failure!
Old 09-04-17, 12:49 PM
Handyone's Avatar
I use emery cloth for both soldering and cleaning for a new ferrule. I have an outside diameter brush tool but rarely use it.
I do use the inside diameter brush a lot.
Old 09-05-17, 06:34 AM
G
Thank you. That's pretty much what I did. I re-plumbed the sloppy work under my kitchen sink with new compression stops and was concerned the ferrule wouldn't seal on the scratches left from a brush. I've never had an issue with brushing soldered fittings but I'm sure solder flows into the scratches and fills small voids.
This was 40 year old copper with paint & oxidation on it that took more than the usual amount of scrubbing to remove.
