How to secure pipe to outside of foundation
Old 09-19-17, 06:38 PM
hi all!
so, I am working on my water line project (I'll try to fine link), and still assuming I will have a piece of copper coming up from an underground PEX water line and it will terminate in a hose connection from which I can connect to a whye off my existing hose bib
my question: I had been hoping to have to copper rise directly at the foundation and then I could attach a strap to secure it, above grade.
my issue: there is a 4" drainage pipe flush up to the foundation. Is there a stepped out strap or something I can use? Just not sure how to keep the pipe from moving around after backfill...
Old 09-19-17, 06:42 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Either a 4x4 post in the ground or threaded rod, a split ring, and wall plate to mount to foundation..
Or if you can get close to foundation a piece of unistrut to the foundation and a strut clamp...
Old 09-19-17, 06:43 PM
This shows the pipe
Old 09-19-17, 06:46 PM
Thank you! I'll look for ring and face plate option!
Old 09-20-17, 05:23 AM
P
Received 1,849 Upvotes on 1,655 Posts
If you are coming up out of the ground with copper why not use some 90 degree fittings and have the pipe make the turn to be routed right next to the foundation wall?
