Growling noise when shut off water or flush toilet.
Old 10-04-17, 09:43 AM
Growling sound when shutting off a water facet or flushing toilet. Also shutting off outside facet causes the same thing. City has backflow preventer on incoming water line and I have installed an expansion tank. When expansion tank installed, Plummer inflated to ~ 55 psi and no noise or growling for several years. Now whenever toilet or outside valve closed I get the growling noise as the water shuts off. What can be the cause of this growling noise? Has the expansion tank psi dropped, outside water pressure increased so that I now receive this growling? Do I need to reduce the psi in the expansion tank?
MLogan
Smyrna, TN
Old 10-04-17, 12:02 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Expansion tank may have a leak. There should be a schrader valve give it a quick push and see if water comes out.
Old 10-05-17, 10:47 AM
I removed the cap and tried the valve but no water came out, just a little air. I measured the psi and have 50 psi. Should I have 60 psi?
MLogan
Smyrna, TN
Old 10-05-17, 01:26 PM
pugsl's Avatar
Plumbers should be in later. What is making noise? Are the pipes rattling?
Old 10-05-17, 01:37 PM
Received 3,627 Upvotes on 3,251 Posts
There maybe a problem with the pressure reducing valve. You need to check the house water pressure to see where it's at. You can use an inexpensive gauge to measure it.
3/4 in. Plastic Water Pressure Test Gauge- The Home Depot
