Cover window to stop pipes freezing?
This is a basement in a old house.
the window seems to be open to the outside with very cold freezing weather in the winter. The pipes have not frozen in the past but I'm not sure how. Cold and hot water pipes run in this area plus plumbing.
What's the best solution for closing off the hole without glass?
this is all in the crawl space area under the house but the window is next to a deeper section of it
Well let's think about that. If you have uninsulated water pipes, do you want / need a lot of air movement when it's -25C outside? Once the weather has warmed up, you can remove your insulation. (Which is why i would just tightly fit styrofoam.... and not caulk anything shut).
Crawlspaces are normally vented, usually by foundation vents placed every so often in the foundation. There are also those that don't believe in ventilation and instead have the foundation completely sealed off [including vapor barrier on ground/walls] and use either the HVAC system or dehumidifier to remove any moisture. Windows are not normally part of a crawlspace's ventilation.
The foundation only has the possibility for vents at front and back. There are other units on either side.
there's no vent at back as far as I can see.
Or do you mean floor vents in the ground floor units?
