Quality 1/4 turn toilet shut off?
Can someone recommend one? Normally I'd use the one Sharkbite makes but I keep reading about horror stories using them with city water because of the chlorine eating the o-ring, but who knows, could be bull****.
I absolutely hate the multi-turn ones.
Never heard of Bluefin. In my experience a mini-ball is not much better than a multi-turn so any valve will work.
If you want your valve to last, turn it on and off once in awhile. The valves fail because they are never used.
I have never had any problems with Brasscraft 1/4 turn valves. As mentioned, it's generally accepted that you should operate any shutoff at least once a year to keep them loose.
