Hole in rain downpipe
Old 11-25-17, 02:15 PM
Q
Received 1 Upvote on 1 Post
Seems like the previous owner cut a 1.75" hole as a clear out in this pipe instead of climbing on the flat roof to clear it.
it started leaking today with heavy rain and his previous repair failed. I have had to make a temporary fix with all that the hardware store had which was a 1.25" drain stop.
I used quick set paste epoxy to seal. So it's a pic pvc seal to a slightly rusty cast iron pipe. 3min set, 60cure
I pushed the pvc onto the epoxy and sandwiched it. My worry is that it doesn't make a proper seal.
How does epoxy seal in a situation like this with only slight pressure pushing on the parts?
Btw it's an old house. Ignore the fact there is a drain running through the center of a room!
Old 11-25-17, 04:25 PM
B
Received 243 Upvotes on 216 Posts
It appears a larger diameter pipe is just above or sitting on the patch. Could this be causing the leak? A pipe repair clamp will make a better fix, but you will have to go to a plumbing supply for the diameter needed. How is the larger pipe sealed to the smaller pipe. Out of curiousness, how is the pipe sealed at the roof?
Old 11-25-17, 04:27 PM
Received 125 Upvotes on 110 Posts
If it's leaking it's because the drain is pluged up.
Old 11-25-17, 06:13 PM
Q
It's a 4" rain pipe probably shared with the house main waste stack - that's how they used to do it 100 years ago. It's leaking because someone drilled a massive clean out hole in it and the original plug failed! The picture shows the plug I had to repair it with!
Here is how it looked before and why it leaked:
Old 11-25-17, 06:41 PM
Received 3,485 Upvotes on 3,128 Posts
I would severely doubt it was put in for cleaning. More likely something was connected there. If that drain line was plugged.... putting that hole in as a cleanout would have resulted in a flood.
I would try to locate a rubber plug to put in there.
Old 11-25-17, 08:01 PM
Q
1.75" rubber plug exists? Like a cork style you mean?
think the epoxy will work?
Or epoxy the entire hole and then fiber wrap?
Old 11-25-17, 08:17 PM
This would be the style I'm referring to. This is a 10 pack.
10-Pack-CleverDelights-Rubber-Stoppers
