Are these traps set up properly?
Old 11-29-17, 08:09 PM
R
When I run water in the kitchen sink I often notice a foul smell, I was wondering if these traps might be letting gases past.
Thanks!
Old 11-29-17, 08:37 PM
XSleeper's Avatar
Received 1,812 Upvotes on 1,629 Posts
No, they are not proper. Those are effectively set up as S-traps, and unvented at that. So when water runs, the suction can siphon the trap out, releasing sewer gas.
Old 11-29-17, 10:02 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Should be set up like this with an automatic air vent...
You can only have one trap...
Old 11-30-17, 02:32 PM
R
What would be good way to resolve this? I mean how should I run the pipes given my setup. The steel pipes come from a disposer and the white pipes from the other sink basin.
Thanks!
Old 11-30-17, 02:50 PM
XSleeper's Avatar
Imagine that the disposer is hanging on the right in lawrosa's picture.... and do it just like that. Use a straight discharge pipe to come out of the disposal.... no need for a down elbow. (But reverse everything for your situation.) And put the AAV up high as you reasonably can.
Old 11-30-17, 04:17 PM
lawrosa's Avatar
Super Moderator
Like this kind of.. But use a straight tail piece out of the disposal instead of the black ellbow they show...
Old 11-30-17, 04:25 PM
R
thanks, I'll look into this.
Old 12-01-17, 06:30 PM
R
Would the tail piece from the disposal have a downward slant to it or just straight across into the other pipe?
Thanks!
Old 12-01-17, 07:20 PM
lawrosa's Avatar
Super Moderator
Straight across is fine.. Its so short... Just dont up pitch it...
Old 12-02-17, 03:16 PM
R
I was wondering how to resolve the fact that the discharge pipe from the disposal comes out at an angle such that a straight pipe out would end up behind the white pipes. How can I get that to work. The pipe out of the disposal will have to join the white pipe from the drain. I saw a video wherein "flex tubing" was used, kind of a flexible plastic but I haven't been able to find a product by that name.
The pic isn't great but gives an idea of what I'm talking about.
Thanks!
Old 12-02-17, 03:21 PM
XSleeper's Avatar
The disposal will rotate 360 degrees... all you have to do is turn it.
Old 12-02-17, 03:27 PM
T
Received 69 Upvotes on 64 Posts
If you loosen the disposer from the steel flange (sink drain) you will be able to rotate the disposer so the discharge points to the direction you need.
Old 12-02-17, 04:05 PM
lawrosa's Avatar
Super Moderator
Deleted....................................
Old 12-02-17, 04:21 PM
lawrosa's Avatar
Super Moderator
You will need to cut that whole mass out. Get a coupling on the pipe down at the cabinet floor. And repipe the whole thing...
Youll need.
1 glue and primer
2 One p trap 1 1/2
3 one air vent 1 1/2
4 one 1 1/2 sanitary tee
5 one coupling
6 5 ft 1 1/2 pvc pipe
7 one side waste drain kit
8 two 1 1/2 tail pieces. One long to reach other sink..
Your going to turn the disposal and put a straight tail piece out after you remove the elbow thats there...
Old 12-02-17, 04:24 PM
lawrosa's Avatar
Super Moderator
OOOhhhh I found one......
It should look like this when done!!!!!!
But you probably dont need that extra piece that makes the trap so low... Since your repiping the back piece with the tee and air vent you can make it to exact height you need,,,,
Old 12-03-17, 11:11 AM
R
Wow, Thanks Lawrosa! I really have a plan now.
Old 12-03-17, 04:58 PM
R
What would the glue and primer be used for?
Thanks!
Old 12-03-17, 07:17 PM
lawrosa's Avatar
Super Moderator
Glue and primer is for gluing the pvc together....
Old 12-05-17, 10:38 AM
R
Would I have to cut the sanitary tee off?
Thanks
Old 12-05-17, 10:44 AM
XSleeper's Avatar
Yes. See post #14... bottom pic.
Cut on red line, replace it with a coupling.
  #21
Old 12-09-17, 12:12 PM
R
In going from the p trap to the hub, is the idea to cut a short length of PVC and glue one end into the hub and the other end into a trap adapter?
Thanks!
  #22
Old 12-09-17, 01:06 PM
lawrosa's Avatar
Super Moderator
Yes.. Whatever length it takes to get you closer to the trap arm...
I assume your using the elbow off the disposal?
  #23
Old 12-09-17, 02:30 PM
R
I'm not sure. The guy at HD was persuading me to, saying a straight pipe could pop off from the pressure out of the disposal. I'm not sure that's accurate but he also said I could cut the elbow off the white pipe and go in straight. I have to look at the disposal pipe and see how snugly I can connect a straight tube as it will only held on by a spring type hose clamp.
  #24
Old 12-09-17, 02:49 PM
lawrosa's Avatar
Super Moderator
Straight tail piece.. The tailpiece is held on with the metal adapter mount at the GD end...... It aint coming off...
The tailpiece has a hat on one end,,,
https://www.homedepot.com/p/Everbilt...9803/205153885
  #25
Old 12-09-17, 02:51 PM
lawrosa's Avatar
Super Moderator
See the metal adapter on the GD? You slip the tail piece through it....
  #26
Old 12-09-17, 02:52 PM
lawrosa's Avatar
Super Moderator
The top piece coming off the top of your tee should also be a tail piece and not the tail piece adapter as you show...
  #27
Old 12-09-17, 03:06 PM
R
ok, thanks! I'll make the adjustments.
  #28
Old 12-09-17, 04:18 PM
R
How can I get that metal adapter on the GD? Mine has a black piece of hosing on it, can that be removed?
Thanks!
  #29
Old 12-09-17, 05:38 PM
lawrosa's Avatar
Super Moderator
Hmmm what GD is that? .
  #30
Old 12-09-17, 05:43 PM
lawrosa's Avatar
Super Moderator
Looks like the evolution...
Ummm One screw I believe removes the plate... and that rubber gets removed... Check it out andlet us know....
https://www.insinkerator.com/resourc...&type=document
  #31
Old 12-10-17, 10:34 AM
R
Yes, it's an evolution pro essentials. I unscrewed the hosing assembly but there doesn't appear to be any threads or any way to screw an adapter in.
  #32
Old 12-10-17, 10:40 AM
lawrosa's Avatar
Super Moderator
What did you unscrew? Did a metal piece come off with a hole in it? No you dont thread anything in...
The instructions show a tailpiece can be used but I need to see all you removed
  #33
Old 12-10-17, 10:41 AM
lawrosa's Avatar
Super Moderator
I think that black ring comes out????
  #34
Old 12-10-17, 10:56 AM
lawrosa's Avatar
Super Moderator
Could it be that the tailpiece fits into the rubber piece you removed??? To tell you I am not sure as I am not there...
Ill read through instructions again...
  #35
Old 12-10-17, 10:58 AM
lawrosa's Avatar
Super Moderator
Page 4 shows tailpiece slipped through ring... ( No rubber fitting as in picture)
  #36
Old 12-10-17, 12:05 PM
R
There appear to viable options for connecting the GD so I put that on the back burner and went beyond the point of no return by cutting out all the old piping. I used a hacksaw and you can see the results. Is this OK or do I need to get a smoother more even cut? Does the Tee just glue in place there?
Thanks!
  #37
Old 12-10-17, 03:12 PM
lawrosa's Avatar
Super Moderator
That cut is fine... But you dont put the tee there... You put a coupling and a piece of pipe to the height you need for the tee...
Did you not understand the pics??
You better dry fit all of it and let use see it before you glue.... ..
I only hope its not too late....lol
  #38
Old 12-10-17, 06:17 PM
R
Sorry for my previous question, I hadn't thought it through yet. Anyway I went ahead and did the job. It ain't pretty but hopefully it won't leak.
Thanks for all the patience and help lawrosa!
