Studor vent ridges on adapter
Old 12-09-17, 05:28 AM
Q
Received 1 Upvote on 1 Post
The 1.5" to 2" adapter seems to have ridges on it. Won't this form a bad seal with standard smooth 2" pipe?
Old 12-09-17, 06:07 AM
Received 125 Upvotes on 110 Posts
I'm not seeing an adapter just the valve.
Pipe slides inside of the valve not the outside.
Old 12-09-17, 06:22 AM
Q
The valve is on the left, the right side is the adapter for a 2" pipe. I can take the valve out and plug it into a 1.5" so it comes in 2 separate parts but not sure why the ridges are there.
Old 12-09-17, 09:19 AM
Handyone's Avatar
I haven't installed a 2" adapter before. I think the ridges go up, not down into the pipe. There should be a gluing hub at the bottom of the adapter or maybe threads.
It looks like the way it was packaged is not the way you would install it.
