Cutting natural gas pipe
Old 12-10-17, 12:53 PM
B
Received 9 Upvotes on 9 Posts
Is it safe to cut a 1/2" black iron natural gas pipe with a sawzall or angle grinder once the gas main is shut off? It's a LOT of work disassembling "stuff" and then putting it back together if I have to unscrew the old piping. But I'll do it that way if I have to, to be safe.
Old 12-10-17, 01:18 PM
Received 3,493 Upvotes on 3,136 Posts
Once the gas is shut off there is little to no residual gas pressure left. You could vent the pressure out thru a stove. Cutting the pipe is sometimes the only way to break in to the middle of a gas line.
Old 12-10-17, 02:24 PM
B
Thanks for the help! Saves me a lot of work.
Old 12-11-17, 06:54 AM
G
Received 1 Upvote on 1 Post
So the gas standing in the pipe won't ignite from the sparks?
Old 12-11-17, 10:02 AM
Z
Received 372 Upvotes on 332 Posts
Nope, whatever gas is in the pipe will be bled by the water heater. I usually open the gas valve to the range to bleed off the little pressure that's in the system, but I'm sure it's not even necessary.
Old 12-11-17, 10:54 AM
B
One final question and I hope I can leave you alone. Is there any problem mixing black iron pipe and galvanized elbows?
Old 12-11-17, 03:10 PM
Norm201's Avatar
Received 678 Upvotes on 601 Posts
Depends on who you talk to. Some in this forum say it's not a good idea because flakes of galvanizing will fall off and clog gas jets. I suppose that it's possible, but very unlikely. Years back I called the gas company and asked if I can mix black iron and galv pipe. They told other than cost , there is no problem. I've done it and have had no problem. There is no corrosion or bad effect with galvanized pipe being used on gas service. But it is costly.
Old 12-12-17, 09:05 AM
B
How about that. I cut the black iron with my angle grinder and nothing blew up!! Thanks for the help. Life is good.
Old 03-21-18, 09:30 PM
C
Yes but just to be safe, once you close the gas main valve, just turn on the kitchen stove (assuming it's gas) for a few seconds to burn off whatever is in the line before you start. The only thing with using a Sawzall is, there could be some small sparks from cutting steel. If there's any material amount of gas in the line, that would be bad ...
