Drainage system setup
Received 0 Votes
What do I need to get to complete my sink drainage system. In the wall there is a pipe that would accept a threaded pipe. I have no idea if that exists and what to put on it from there to attach to the faucet tailpiece Any ideas? Thanks.
Screw in: https://www.homedepot.com/p/1-1-2-in...D112/100347535
Then glue in: https://www.homedepot.com/p/1-1-2-in...D112/100347086
Then a slip trap: https://www.homedepot.com/p/Everbilt...704B/205153793
Add a tail piece as needed: https://www.homedepot.com/p/Everbilt...793A/205154109
All the parts X linked to are also available in ABS, especially in California. ABS is easier to glue IMO.
Apply about 2 wraps of Teflon tape on the adapter that screws into the wall and coat the tape with Teflon paste. Just snug the fitting up, it doesn't need to be really tight.
I also apply Teflon paste to the lower mating surface of the trap, the 'ground' surface.
A standard 1-1/2" slip tube trap comes with two washers. One washer is 1.5", the other washer is 1.5 OD and 1.25" ID.
If not just purchase a separate slip nut and the package contains 2 washers. (PVC in link but black is available)
Oops, wrong link, just purchase a 1-1/2" slip nut packaged.
