Two Connections for Water on Manufactured Cottage
Old 12-23-17, 10:05 AM
We are setting up a small cottage for my mother-in-law on our property. I could use some feedback for the water connection. There are two PVC connections at the area indicated Fresh Water Connection. Is the PVC pipe that has the threaded water hose fitting on the end for an outlet? Is the bare PVC for the connection to the Water Main in? Photo attached. Thanks in advance for your input. Merry Christmas and Happy New Year!
Old 12-23-17, 10:49 AM
Received 786 Upvotes on 689 Posts
I would think the PVC with the threaded coupler would be the water supply point. The other PVC might be from the water heater.
Old 12-23-17, 01:07 PM
I was able to find out from manufacturer https://factoryexpodirect.net/floorplan/valencia/ that the pvc with threaded fitting is the water main inlet. The other PVC is drip for water heater pan.
