pipe noise
Old 02-02-18, 12:50 PM
Received 753 Upvotes on 658 Posts
pipe noise
A few weeks ago we replaced the PRV on my son's mobile home. A week later he noticed that the plumbing hums when you turn on any tap. We replaced his kitchen faucet today and I got to hear the hum - it's fairly significant. When the PRV failed he had 120 psi for a day or two. I assume it might be related to that ?? any ideas on how to quieten his plumbing? I think it's all copper.
Old 02-02-18, 01:24 PM
F
Change the setting on the pressure reducing valve slightly, either up or down. You MAY need to set it lower by several psi.
Old 02-02-18, 01:31 PM
I'll tell him to try that. Right now it's factory set in the 50-55psi range.
Just called him while waiting the mandatory 180 seconds and it sounds like the new PVR might have gone bad, he's back at 120 psi
Old 02-02-18, 01:49 PM
F
It is more likely that a piece of dirt has stuck under the seat of the valve. Having a large flow of water, from a bathtub filler or an outside hose bibb may clear it. Otherwise disassembly, cleaning and reassembly will be needed. It is also possible the dirt caused a cut in the seat and a rebuild would be necessary. Installing a strainer ahead of the PRV might be a good idea.
