How do I undo this coupling?
Old 02-10-18, 08:41 PM
ukrbyk's Avatar
Received 48 Upvotes on 39 Posts
Picture says it all.
I need to remove that leaking valve. Never saw plastic coupling or fittings like this. Red tubes are some sort of rubber material. It's part of circulation pump circuit.
Old 02-10-18, 09:38 PM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
It's a type of pex that is mechanically expanded, then pushed on the fitting. As it contracts it cinches down tight on the connection. https://www.uponor-usa.com/pextalk/2...ngs-are-1.aspx
Pretty sure the only way to remove it is to cut it. Without the expensive expansion tool, you'll have to use a different method of remaking the connections.
Old 02-11-18, 01:24 AM
F
You might be able to get it apart by using a heavy duty heat gun to soften the plastic but as Vic states you will need to use a different method for the final repair. Those particular connections are a one-shot deal as far as I know.
Old 02-11-18, 05:54 AM
ukrbyk's Avatar
Darn. And with circulation pump out of equation takes 3minutes for hot water to get to bathroom.
And entire piping into the wall is those connectors.
Old 02-11-18, 06:19 AM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
Can't see enough of tubing to help. Take a couple of pictures showing more of tubing.
Old 02-11-18, 06:50 AM
XSleeper's Avatar
Received 1,743 Upvotes on 1,567 Posts
Page 11 of this pdf describes the procedure to remove.
https://www.google.com/url?sa=t&sour...eQ9Gqtj7lB8v2h
Home Depot carries this style.
https://www.homedepot.com/p/Apollo-1...hoCRUMQAvD_BwE
Old 02-11-18, 09:42 AM
ukrbyk's Avatar
It's done.
$150 took care of this.
Same time opened 13 you circulation pump and cleaned it.
Thank you all. Plumber, who is family friend, told me that those fittings are actually very good as they do not rust or leak. Of course, HE had the tool.
Old 02-11-18, 09:44 AM
Gunguy45's Avatar
Super Moderator
X,
I only see 3 pages, none with actual removal info?
Old 02-11-18, 11:27 AM
XSleeper's Avatar
Sorry, wrong link. Too late anyway.
https://www.google.com/url?sa=t&sour...Pdsg8ByX067ieZ
