Stripped Shower Handle Screw
Received 0 Votes
I, like a complete idiot, completely stripped the screw that secures the shower handle into the valve. To make matters worse, the handle is now stuck without the back plate in place.
I had a plumber come out who recommended opening the wall behind the valve and replacing the entire valve/handle for ~$650. The wall is in the master closet behind a built-in and not visible, so that's one thing that idea has going for it. The house/valve is 10 years old.
Wondering if anyone has any ideas to either:
Thank you for any advice!
- Get the cover back on and just leave the faucet handle stuck / stripped but still usable. There is a lip it cannot fit over and I could not find any 'adjustable' covers online.
- Get the handle off without having to cut into it.
Leaving handle as is is one option but I would get one of these first. 2nd row, 3rd in is a single I would try
https://www.lowes.com/pl/Screw-extra...crew+extractor
If that doesn't work drill the head off screw and remove handle. Use pliers to remove rest of screw. Get a brass screw to replace.
Received 0 Votes
Just wanted to follow up on this and say that Grabit #1 did not work, however Grabit #2 did the trick! Thank you so much for leading me in that direction and helping me avoid something more involved.
