Water heater power vent will not shut off
Old 02-21-18, 04:42 PM
V
we have a water heater that works great but the power vent inducer will not shut off. How can we fix it? We shut off the water heater to make sure the power vent won't burn out but I need the hot water so can you help?
Old 02-21-18, 06:11 PM
P
Received 1,841 Upvotes on 1,648 Posts
You can start by telling us what water heater you have... What is the brand and model number?
Old 02-26-18, 10:51 AM
V
Water heater
Brand. STATE. 75. Gallon. Model # PRV75 PRV T1. Is it the limit switch?
Old 02-26-18, 06:57 PM
Z
Received 372 Upvotes on 332 Posts
I honestly don't know much about them, but my model has a small tube connected to a pressure switch that senses a pressure change when the heater turns on. I understand that the tube can become clogged - or the pressure switch can fail.
Others with more experience with power vented heaters can probably give better advice though.
Old 02-26-18, 07:23 PM
Received 3,484 Upvotes on 3,128 Posts
I cannot find any listing anywhere for that water heater. No series listed like that at State either.
Limit switch... I doubt it.
The pressure switch only allows combustion to take place when the proper flu pressure is sensed.
Your problem sounds like either a stuck relay inside the controller or it may possibly be a variable speed venter in which case the variable speed supply is shorted on.
How old is the unit ? Possibly under warranty ?
