One-Way Check Valve
One-Way Check Valve
If you're not familiar, this Wikipedia article explains the basics of check valves:
https://en.wikipedia.org/wiki/Check_valve
The images show common examples of check valves in unpressurized and
pressurized systems. A toilet tank flush valve flapper and a water pump.
I'd like to add a check valve to a 1-1/2" sink drain. The question is, are there
check valves that will open from the flow of water going down a sink drain?
The only pressure on the mechanism would be a few ounces of water. A very
sensitive spring, ball float, or some other method I can't imagine is required.
The drain pipe is brass with chrome plating. A check valve that fits the 1-1/2"
drain would be great, but a larger diameter pvc or brass valve would be ok too.
I can build almost any kind of basic pipe adapter in my shop.
You may be wondering why I need a check valve. If you can help me find the
right valve I'll explain.
Thanks guys.
Thanks guys.
There are none that I'm aware of.
You'd need some type of floating ball system.
Something along this line..... Wager Co. Inc. - 2100 Mushroom Check Valve
Received 38 Upvotes
With only one exception that I can think of ALL check valves are one-way. To the best of my knowledge they do not make check valves for most individual fixture drains, floor drains being the only exceptions to that I am aware of. They DO make a type of check valve for main sewer drains called a backwater valve but they are only used when there is a significant probability of a sewer running backwards.
Perhaps I don't understand what you're asking for. Wouldn't a spring-check do what you're looking for? You might have to fiddle with the spring a bit to get it right. I'm sure you can get them in 1-1/2".
