Basement drain backs up after every shower
Old 05-12-01, 08:39 AM
Unhappy
Anyone have any idea what causes this? I rented an Auger and (thought) I cleared out the basement drain, but it didnt seem to help :-/. For about the past 2 weeks whenever a lot of water is drained (i.e. shower, washer) it comes back up in the basement drain...it seems to be getting worse too (each time it creeps a little further out)
What else can I do?
Any info helpful,
T
Old 05-12-01, 01:51 PM
Two possibilities I can think of: You have not adequately cleared the drain line, or you have a plugged vent.
The vent is easiest to deal with, so look for inch and a half to two inch pipes coming out of the roof. Look down them and remove any leaves, branches, bird's nests, etc. and then use a garden hose with a high pressure nozzle and flush them out good.
If that does not work, either call a roto-rooter company, or rent a power auger with a longer cable.
Old 05-12-01, 05:22 PM
Plumber2000's Avatar
I doubt there is any thing in the vent, you need to clean the line out to it's full bore, anything less, you will always have the problem.
HTML code is On
