Waste/stack
Old 03-15-18, 09:28 AM
Waste/stack
I have to reroute a 1 1/2” waste vent pipe, is it possible to vent it through an exterior wall?
Old 03-15-18, 11:07 AM
P
Received 1,849 Upvotes on 1,655 Posts
Yes, but it's ugly. This article describes venting. The section titled Table of Plumbing Vent Clearance Distances to Building Features describes where the vent can terminate.
Running a vent outside through a wall was generally only done on old, pre-indoor plumbing houses. Doing it now would be a clear sign of a hack/amateur job. Most houses it's possible to route the vent line up inside the walls and through the attic and roof.
Old 03-15-18, 04:35 PM
Z
Received 372 Upvotes on 332 Posts
Depending on your locale and what it's venting, you could also use an air admittance valve (AAV). A vent out of the house is always preferred, but it's a possibility if you don't have any other good solutions.
Old 03-17-18, 05:27 AM
Thank you for the link, very helpful
