Sewage smell from washing machine standpipe
Old 03-21-18, 07:45 AM
Looking for suggestions..
Sewage smell coming out of washing machine standpipe.
Drain hose is only a few inches in so it’s not blocking trap.
Bleach works for a week then smell comes back.
Smell usually comes a day after wash is done.
Attached is a picture of plumbing in hopes someone can see if anything looks wrong.
Thank you
Old 03-21-18, 09:58 AM
Z
Received 372 Upvotes on 332 Posts
Your setup looks pretty correct. The trap isn't quite right, I would rather see a street ell on the right side of the trap - but I honestly can't see any reason it would really make a difference.
I'd imagine you just have some mold/fungus/gunk down at the bottom of the trap. The bleach helps kill it for a bit, but then washes out and whatever is there just keeps coming back. I don't think it's actually sewer gas, just gunk in the pipe smelling.
Maybe someone here has a good idea on how to clean/scrub it without taking it apart and replacing it.
Old 03-21-18, 10:41 AM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
Only thing I could think of the vent pipe is blocked. If it is the water in trap would siphon out.
Received 3,479 Upvotes on 3,124 Posts
The PVC line connected above the trap would need to be confirmed as a vent.
If it were a wet (drain) line from above... it could draw the water out of the trap.
Old 03-21-18, 11:27 AM
Thanks all! These are great ideas that will look into.
