Help identify pipe
Received 0 Votes
Help identify pipe
Can anyone tell me what this pipe would be for? This in on the ceiling in my basement and seems to be leaking water down on occasion. I'm assuming when raining but can't be sure. Just thought I would get some ideas before calling someone out to look at it. I provided pictures.
Thanks,
Thanks,
It might be a vent line that got cut. I would glue a cap or a cleanout onto it.
Is there any plumbing nearby in the basement below? Someone might have eliminated or relocated the basement bathroom.
Received 0 Votes
Any idea of why it would be leaking from inside the pipe? It's not a lot but I can definitely see some water stains coming down the insulation that is on the basement wall.
The vent pipes are open on the roof and if it rains, water gets into the vent pipe... that water is supposed to eventually go down the drain. So if that is a vent pipe, any water in it would ordinarily be heading for a drain. Instead it drains onto your ceiling.
It could also be condensation during winter months... cold air coming down the pipe hitting warm moist air.
Received 0 Votes
Now that I think about it I have a rough in bathroom in the basement. I assume this was going to be the tie in for the vent if a bathroom was ever installed downstairs.
If you cap the pipe at the bottom it will slowly fill with water over time. You could cap it on the roof to prevent water from entering in the first place. Just make sure you cap the correct pipe as you likely have at least one or more other vents sticking out of your roof.
No need to cap it, but you could put 2-90 degree fittings on the roof to prevent water getting in. No glue, needed normally. I did that at my old house...more to lessen venturi effect from the crazy winds we get than for rain.
Before you start capping, I would figure out a way to confirm where the water is coming from. Whether it's coming from inside the pipe or outside. Then you can figure out the best course of action to fix it.
If it were me, I'd temporarily cap it with a rubber cap. Leave it for the next storm and see how it does. then open it up with a bucket underneath.
