Good tool to disassemble the pipe union?
Hello all,
I need to disassemble the pipe joint in case of pump failure.
What is the good tool to loosen the screw on joint?
Thank you
Thank you
That joint is called a union.
You are showing a pair of slip joint or channel lock pliers. They come in all sizes.
A larger pair.... also known as water pump pliers... is also a good choice.
Tell you what...I've got a pair of these...https://www.channellock.com/product/of-2/
And they come in very handy for all sorts of things. Strainer basket nuts, PVC slip joint nuts, opening pickles, etc. Probably picked them up at HD one time..dunno if they still sell them there. Yep...they do...https://www.homedepot.com/p/Channell...-209/202247297
Don't think I paid that for them.
very helpful,
I found a similar one from HF for $24.99.
https://www.harborfreight.com/20-in-...ers-63830.html
Jaw opening 5-3/8 in.
Oil Filter Pliers $7.99
https://www.harborfreight.com/2-inch...nch-36778.html
Thank you
Thank you
