Installing a faucet. Where do I need thread tape?
Old 05-11-18, 03:05 PM
Question Installing a faucet. Where do I need thread tape?
I'm putting a faucet back in after installing new kitchen cabinets. I noticed none of the treaded connections had thread tape on them from when originally installed. Should i use it or not. My thinking is "it can't hurt". But those are often famous last words.
Also, the rubber seals under the faucet where it goes thorough the counter top are pretty dried out. Can I just use plumbers putty to seal them?
Thanks,
Jim
Old 05-11-18, 03:49 PM
Received 3,485 Upvotes on 3,128 Posts
Plumbers putty is an acceptable seal. Sometimes silicone is used in the case of a stone countertop.
Plumbers putty has oils in it that can leach into lightly colored stone.
Most faucet connections don't require tape but if yours had it on then it may have been needed. Hard to answer without knowing the exact type of connection.
Old 05-12-18, 06:55 AM
Z
Received 372 Upvotes on 332 Posts
Like Pete said, the connections from the faucet to the angle stop does not require thread tape. Because of the rubber washer inside, tape can actually make the connection leak.
