Flush is continuously leaking inside but no water shows on the bowl
Old 05-28-18, 01:03 PM
Flush is continuously leaking inside (water flowing inside continuously, making a sound) but no water shows on the bowl. Usually, if the rubber flap is damaged, you can see water continuously flowing into the toilet bowl
In my case however, I can hear water running inside the flush tank but I am not sure where it is going
The sounds seem to come thru the black plastic thing with the blue top.
Also, the white small pipe was loose. Is it supposed to go inside the white part? I put it in thinking it would stop the water sound but it did not
Old 05-28-18, 05:06 PM
P
Received 1,852 Upvotes on 1,658 Posts
It sounds like you have a leaking flapper valve. Even if you can't see the water entering the bowl that's where it's going.
Old 05-28-18, 05:33 PM
Z
Received 372 Upvotes on 332 Posts
Put a few drops of food coloring in the tank. You will likely prove Pilot Dane's guess by seeing the colored water drain into the bowl little by little.
Old 05-29-18, 01:40 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
The "black plastic thing with the blue top" is the fill valve. When you flush, the float in the water drops and allows water into the tank while some water also comes out the white hose into the white plastic tower (the overflow tube), which runs down and refills the bowl. As the water rises, the float is lifted and shuts off the water.
You could have a tiny bit of grit or build up in the valve allowing water to constantly flow. This appears unlikely as the water level in the tank would rise until the water went into the overflow. If this picture was taken long after the last flush, then the water would be higher. If it was flushed just before the pictures, then wait 30 min or so and see if the water level rises. Flush, and after the valve shuts off, make a pencil mark at the water line. Check it 30 min later. Rising water means the valve needs maintenance or replacement. Leaky flapper normally will cause the fill valve to "cycle" off and on in my experience. Water leaks out...water level drops...fill valve opens...water rises...fill valve closes. Constant running points more towards a fill valve issue.
You can find everything you need by searching for "WDI fill valve maintenance". Videos galore.
PS...it also appears your hose into the overflow may be pushed in a little far. That can cause siphoning of water out of the tank. It should have it's end pushed in just far enough to hold it, but not below the normal waterline in the tank.
