Please Help, I am Desperate
I知 not sure how to post pictures cause I知 barely on forums so if you really wanna help, I値l email it to you lol.
under assumption that the clog is from burger fat and grease
Have tried boiling hot water
have tried liquid plumr
Now currently using an auger to unclog but it will not get past a 90 degree bend. Yes I took the P trap out(I think). We got it through the bend once some howbut we do the same thing every time. Not sure how it doesn稚 work.
First, you need to STOP putting grease down the drain. If you pour grease down the drain you will continue to have clogs.
It is common for there to be a 90 degree bend just inside the wall behind a sink. There are small drain augers that can be worked though the bend. Unfortunately grease clogs can be very difficult to remove so it might not be a quick and easy process.
As Pilot Dane mentioned snaking grease clogs is difficult as the snake typically pokes a hole through it. But it's certainly doable.
If you want to post some pics - look here for instructions:
How to insert pictures.
