Septic System tie in?
Old 06-20-18, 01:01 PM
I have a fairly new sewerage system (a few years), it's a mechanical system(pumps air into tank).
I would like to add a washing machine drain to this existing system.
1. I can splice a 4x4x2 Y into the 4" line headed too the tank.
This will be a bit tricky because 4" pipe is stiff, plus there are other fittings along the way("45 deg el).
2. I would like to go directly into the concrete tank if I could. There should be a "knockout" on the tank to tie into. This tie in pipe would be 2" PVC. What do you think?
Also, are there any other requirements for the 2" pipe?
Old 06-20-18, 01:36 PM
P
Received 1,840 Upvotes on 1,647 Posts
Why in the world would you want to run another drain line all the way out to the septic tank? Just tie into the main line in the house.
Old 06-20-18, 02:11 PM
I won't break my concrete slab in my house to tie in, plus I don't know where the "main line" is, it's under concrete.
Sorry if I didn't make this clear.
Old 06-20-18, 03:42 PM
V
Received 2 Upvotes on 2 Posts
What State or Province is this Septic System located in . . . . because if it was an engineered system, and you alter the projected in-flows, you may have to get a permit issued by that Jurisdiction to make the proposed alterations and to make sure that the existing and approved design can handle the increase.
