Mobile- Trailor Plumbing
Old 06-27-18, 02:37 PM
H
My sink will only drain into the other side- Snaked it from the trap underneath stopped somewhere @ 21 Ft it wouldnt go anymore. Checked clean outs do I have to cut the belly of the trailor open to get to the problem? I did not see any pipes under the skirting? Trailors from 64 sooo any suggestions?
Old 06-27-18, 04:30 PM
Norm201's Avatar
Received 678 Upvotes on 601 Posts
Let me see if I understand this. You have a double sink. Only one side drains. The other side won't. Am I correct? They both use the same drain pipe?
Old 06-30-18, 02:42 AM
Received 759 Upvotes on 664 Posts
Welcome to the forums!
Mobile homes tend to have a lot of funky plumbing but if the problem isn't in the cabinet under the sink you may very well need to cut the belly wrap to access the pipes. They are typically run under the floor joists and covered by the insulation wrap. Is that the only drain with issues?
Can you better explain that?
