Repairing crushed black corrugated drainage pipe
Old 07-09-18, 10:08 AM
B
I suspect I have a section of my 4 inch drainage pipe that is crushed. I will be digging it up soon and replacing just a section of the corrugated pipe. What options do I have to "splice" in a new section of corrugated? Do I need adapter pieces or certain fittings, etc?
Old 07-09-18, 12:26 PM
P
Received 1,841 Upvotes on 1,648 Posts
There are connectors/couplings for black corrugated pipe.
Old 07-09-18, 12:29 PM
Received 753 Upvotes on 658 Posts
The replacement piece should have an expanded end on one end so you'd only need a coupler for the other end.
Old 07-09-18, 02:57 PM
W
Received 60 Upvotes on 52 Posts
Old 07-09-18, 04:59 PM
Marq1's Avatar
Received 1,137 Upvotes on 1,031 Posts
So our of curiosity, why do you think it's crushed?
Old 07-09-18, 07:57 PM
B
It wasn’t draining at the termination point. The reason I thought it was crushed was because I put a drain bladder in there to push through any blockage. About 5 ft from the opening water started to bubble up out of the ground.
After I dug it up, turns out there’s about a 3 foot chunk of the pipe MISSING! How does that even happen. I’m sort of baffled.
Old 07-09-18, 08:35 PM
Z
Received 372 Upvotes on 332 Posts
Glad you found the problem! Contractors seem to often totally disregard drainage piping, or install it early in the construction process and let it get destroyed as construction equipment drives over it all for months.
I personally HATE that corrugated black pipe. I would much rather use the exterior grade PVC piping for gutters and ground drainage. But if it's only a 3' section that needs to be replaced, I'm sure that's the easier answer at this point. But I would confirm the rest of the piping is in good shape!
Old 07-10-18, 05:57 AM
B
I put my drain bladder in the part I just dug up and was able to confirm a good flow to the termination point. Now I just have to splice a new piece in there. Yes, I might do it differently if I had to dig up the whole thing, but it's about 60 ft down my driveway and not worth changing it, at least at this point in time since this part seems to be the only problem.
Old 07-10-18, 06:00 AM
B
Any thoughts on how this happened? I dug down pretty far and wasn't able to find any evidence of this missing piece of pipe? The part on the right I already cut to make it even for the fitting, but both ends were torn, although it did not appear that they went together.
Can't imagine how this ever worked properly (I've been in this house two years).
Old 07-10-18, 06:06 AM
V
Received 2 Upvotes on 2 Posts
That doesn't look very much like corrugated plastic pipe to me . . . . that looks like Orangeburg !
Old 07-10-18, 07:18 AM
B
I know the pic isn't that great, but it's definitely 6in corrugated.
Old 07-10-18, 08:42 AM
Marq1's Avatar
If the ends are torn then at some point some heavy equipment must have caught it.
Since it was buried it eventually gave way.
Who knows what happened but at least you have found the issue and it's a relatively easy repair!
Old 07-10-18, 08:52 AM
V
Did you find the missing pieces . . . . it looks so clean, and like a uniform width (the width of a backhoe bucket) ?
And what's that horizontal white plate item in the soil; it appears to be something that was intended to distribute the weight of anything above the pipe ?
Was there such a white plate above the portion that you dug up ?
Old 07-10-18, 09:04 AM
My guess is some machinery [bobcat?] caught the end of the pipe and pulled it loose/apart.
Old 07-10-18, 11:15 AM
W
Quick reply to this message
You need to decide whether it is 4 in. or 6 in. before you buy the repair materials.
