Drain line into 3" stack
Can I drop a 1 1/2" drain line from a under sink mount pump into a 3" exhaust pipe?
Based on the limited information... I think the answer is yes.
Is it a sink-mounted pump? Most I've seen have a 3/4" output.
If it's a pump mounted in a sump box, it can drain into the stack too, but likely requires a proper vent as well.
Does that help? Or can you provide more information?
