Sink stopper
Old 08-04-18, 11:45 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Sink stopper
The original pivot rod rusted inside the drain pipe and this was a generic part.
Even manually pivoting the rod up as much as possible the stopper will not lift.
Are there different internal rod lengths or being a Delta faucet requires a Delta part?
I have this same set up in other bathrooms so can take apart if needed!
Old 08-04-18, 11:49 AM
Marq1's Avatar
Old 08-04-18, 11:59 AM
XSleeper's Avatar
Received 1,899 Upvotes on 1,705 Posts
Should be standard... unless your tailpiece is something one off. The tailpiece w/ popup is what would be off if the length seems wrong. Unless your generic part was too short? You never know with those Chinese parts.
I would say change both the tailpiece and popup to be sure.
Old 08-04-18, 12:56 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
I had a similar pivot rod problem with a Moen vanity faucet about a year ago. Moen sent me the proper replacement free of charge although it wasn't under warranty. I actually prefer a good Delta faucet, but it's hard to beat good customer service that Moen gives.
