Removing old galvanized drain pipe
Old 05-19-01, 09:43 AM
Question
I'm remodelling my bathroom and need to remove the plumbing used for drainange as we want to reposition the toilet, shower, etc.
The galvanized drain from the toilet is approx 4" in diameter. Other drainage pipes, including the stand pipe, are also galvanized and approx 2.5" in diameter.
What tools will I need to do this?
Also I want to re-plumb using PVC piping. Is it possible to attach PVC piping to the galvinised outlet pipe?
[Edited by stimpo on 05-19-01 at 12:54]
Old 05-19-01, 11:25 AM
Mike Swearingen's Avatar
Cool
The drain pipe that you're calling galvanized is actually cast iron, and is connected with fittings sealed with oakum and lead, I'll bet.
You can connect the PVC drainpipe to it with Fernco couplings.
See http://www.bhglive.com/homeimp/ for general illustrated Plumbing how-to info, and see above under "Build/Remodel" and "Repair/Fix-It" for converting.
Dealing with cast iron pipe (it MUST be properly supported while working with it or it will come crashing down right from the roof) is not easy, but you can do it.
Good Luck!
Mike
HTML code is On
