Vent pipe that goes no where?
Old 08-25-18, 06:27 PM
Received 1 Upvote on 1 Post
While installing a new vanity mirror in the 2nd floor bathroom I decided to see what was behind the wall with my inspection camera. There's a PVC pipe that runs vertically; I can't tell if it comes from the sink below but assume so. The pipe just stops about 5 feet or less above the sink and appears to be capped? It's difficult to tell.
Is this normal?
Old 08-25-18, 07:19 PM
XSleeper's Avatar
Received 1,808 Upvotes on 1,626 Posts
No, not normal. But what you think is a cap might be an AAV (Air admittance valve). Even then, an AAV should not be used inside a wall.
Old 08-25-18, 08:34 PM
Maybe I'll cut a larger hole to take a look... Even then, what could I do to correct the problem?
Old 08-25-18, 08:36 PM
XSleeper's Avatar
Extend it out the roof or tie it into an existing vent that can handle an additional fixture inside the attic.
Old 08-26-18, 11:45 AM
That may be more work than I can do; what is the risk of leaving it as is?
Old 08-29-18, 07:08 PM
Bumping... thank you..............
Old 08-30-18, 04:19 AM
B
Received 47 Upvotes on 43 Posts
Greetings Mainer,
I'm not a pro, but the idea that it is hidden inside a wall implies they were hiding something they shouldn't. If you can handle cutting a hole to inspect I would say do it, and then you know what is there. Then some pictures and the pros here might be able to advise on the next step.
Makes one wonder what else they covered over?
It could also be a point where they stopped and just never got back before the drywall. Could even have holes above already drilled. One can always hope .
Bud
Old 08-30-18, 05:05 AM
XSleeper's Avatar
The whole reason sewer gas vents outside is so that we don't breathe that air. The space in the wall is still inside the house if it's an aav. And if its a cap, then it's not really acting as a vent and whatever fixture it is supposed to be venting might drain slower or gurgle as it tries to draw air.
