Air admittance valve and washing machine, will this work
Old 10-16-18, 04:02 PM
N
Okay, no codes where I am, I need to put a washing machine in my shop, it will be hooked up to the toilet and sink drain, I need to know if this setup will work. Any help would be appreciated. Thanks.
I do apologize for the drawing, no scanner so did it with paint. No idea about plumbing at all, do I need a WZE on it at all. Thanks for all the help.
Old 10-16-18, 07:09 PM
N
Lol, 99 have seen it so far, so is it a stupid question. Remember I have no plumbing experience except for changing pipes out. Need Help.
Old 10-16-18, 07:42 PM
XSleeper's Avatar
Received 1,711 Upvotes on 1,535 Posts
Why do you need an aav? Some reason it can't go out the roof? Also not enough info to even know if it's OK to add a washer onto that line. No sizes, no distances... no idea of the rest of the layout.
Old 10-16-18, 08:14 PM
N
thought that is why...
I thought that is why I am here, for help. If you need to know then the stand pipe will be about 20 inches, the p-trap to the vent pipe will have a 4 inch splice on it, the vent pipe to the aav will be about 35 inches, the drain pipe has a run of about 3 feet. The pipe itself will be 2 inch pvc. And this is a guess. I want an aav because I don't want to drill through a metal roof, it is my shop not my house.
Old 10-16-18, 08:18 PM
Received 3,419 Upvotes on 3,065 Posts
You need to make the standpipe as tall as possible to prevent water from backing up under pressure. Since you don't want to run a standard vent then you must use a AAV to keep the trap from getting sucked dry.
Old 10-16-18, 08:30 PM
N
Thank you very much. I do appreciate the information.
Old 10-17-18, 09:51 AM
Z
Received 366 Upvotes on 326 Posts
Yes, I think it's a good setup. The AAV is set up correctly, and it looks like you have it all in check! Good luck!
Old 10-17-18, 11:37 AM
C
Received 1 Upvote on 1 Post
What is a WZE. If you meant a wye and then a clean out, it cant hurt thats for sure.
Old 10-18-18, 08:05 AM
N
Thank you to everyone
Thanks so much for your help
