Venting alternatives for my gas water heater
Old 05-22-01, 08:09 AM
edbreyer
Question
I'm buying a house whose chimney is oversized for the hot water heater (the furnace is power vented elsewhere) plus - the chimney is no longer serviceable and being removed for remodel purposes. So I need to reconfigure the venting for the water heater.
The obvious solution is to replace the current gas hot water heater with a power vented version. However, since the current water heater is practically new - and power vented models are very expensive - is there anyway I can buy or configure a double wall flue and termination vent so I can safely vent the current water heater through the exterior wall of the house?
I've installed several direct vent fireplaces (which have double walled flues that vent/terminate through exterior walls) - so the concept sounds reasonable/workable - but I want to be safe. Any ideas?
Old 05-22-01, 10:54 PM
plumbguy
retro fit power venting kits are sold for your application
Old 05-23-01, 04:49 PM
edbreyer
Smile Plumbguy...
Can you tell me more about the power vent retro kits? Are they widely available and universal or do I need to contact a specific manufatoror? Also, are they worth the cost/effort (any idea of their cost?) - I just found 6yr warrantied 50 gal powervent water heater for $380 at Menards - much less than I expected.
Your thoughts/advice are appreciated!
Ed
Old 05-23-01, 05:47 PM
plumbguy
thats a better price than the power vent unit itself.
I would jump on it. state also makes a power vented water heater but im not certain if they have a residential model.
good luck
Old 05-24-01, 09:16 AM
edbreyer
Thanks plumbguy!
Thanks plumbguy!
