Replacing outdoor hose spigots. Came across conflicting information.
Old 11-21-18, 10:04 AM
so I moved into an old house from the 50s, and I noticed that one or two hose bibs are leaking. I don't know how old they are but it's definitely warping the siding a little bit, which I plan to replace eventually anyways.
I would like to replace the bibs, however from what I've read you need to turn off the city water at the street which I'm not sure where it's located because I just moved into this house.
am I able to turn this off anywhere else? Like in my utility closet? Or does the outside faucets typically run from the meter itself?
Additionally, can I just seal off the spigot? Like leave the spigot and put a cap on it to prevent water from dripping?
I've also read that in the winter you want to drip your water a little bit, however I'm in North Carolina so I don't know if this is necessary.
basically I would like to stop this leak with the least amount of effort so if there's a stack app I can put on that would be great if I have to do more that would be okay but if I have to hire a plumber that would be more of a negative
Old 11-21-18, 10:10 AM
Received 408 Votes on 384 Posts
There should be a main water shutoff inside the house that turns off all water. Typically if you are in an area where pipes could freeze..... the faucets get shut off at inside service valves and then the faucet is left open for the winter. Just capping a leaking faucet will stop it from dripping but it can still freeze.
Do you have a basement there ? That's where the service valves are usually found.
Typically just inside the house from where it goes thru to outside.
Old 11-21-18, 10:25 AM
Thanks.
So it seems like for a temporary solution I can just get a cab from Home Depot and seal it. Then eventually replace it.
it's a slab foundation so no basement but there is a main room that has all sorts of valves I can turn off
Old 11-21-18, 10:26 AM
Received 260 Votes on 235 Posts
Most municipalities in NC have a shutoff at the water meter. Look for an oval or rectangular cast iron lid along the perimeter of your property. Most houses here do not have a separate main shutoff inside the home though some do. Look around where your water line enters the house.
Most faucets can be repaired. Your dripping spigots likely only need to have their washers replaced. If you post pictures of what you have we can tell you how to replace them. Here are instructions for posting pictures.
Do NOT cap off the end of your spigots and make sure there are no hoses attached during freezing weather. Either of which can cause the pipes inside your home to burst.
Whether or not to drip a faucet depends on your home and the weather (where you are located). Most homes here, even new ones, are not insulated or plumbed for temps below 10f except at higher elevations in the mountains. If you get temps below the teens, especially if it's for more than one night letting a faucet drip is not a bad idea. Look at your water heater. Often it's located in an unheated area so make sure you leave a hot water tap dripping. If your house is older and not insulated well you may need to drip a faucet when it's a bit warmer.
You also have to watch out for freezing pipes if you travel or are away from home for several days at a time. If you are at home your daily water use runs warm water through the pipes to warm them up. When you are gone no water is used so it doesn't get warmed up regularly and is more prone to freezing.
If your house has a crawl space make sure your crawl space vents are closed. If open they are a direct path for cold winter wind to blow under your house and freeze pipes.
Old 11-21-18, 12:15 PM
steve_gro's Avatar
This should be fine if your temps don't drop below freezing:
Everbilt-Lead-Free-Brass-Garden-Hose-Cap-3-4
Old 11-21-18, 04:33 PM
Marq1's Avatar
Received 119 Votes on 110 Posts
Best option is to replace any old fashioned faucets with freeze proof hose bibs and just forget about having to worry about it again!
https://www.doityourself.com/forum/a...1&d=1542843192
Old 11-21-18, 06:41 PM
Pics of what I have
This is the current setup. Perhaps you can tell me the ease of replacing or capping it off.
Old 11-21-18, 11:53 PM
Your top picture is the water heater. Nothing to help us in that picture.
The second is the faucet and the third is some valves.
Is that faucet on the outside wall opposite those valves ?
Old 11-22-18, 05:41 AM
Your spigot can be repaired. It probably just needs a washer. You certainly should NOT cap it off. Capping it will trap water inside the faucet between the cap and closed valve. When it freezes the pressure from the expanding ice will have nowhere to go and it will crack the spigot.
You can replace the spigot with a modern frost proof design. You will need access to the back side of the faucet to install it however. And, a frost proof sillcock is over a foot long so it will stick way out on the opposite side of the wall. In modern houses they are installed to line up with an interior wall so it's hidden inside the wall. If your spigot is somewhere along the wall in a room then it and the piping will stick well out into the room.
Your photo of the valves doesn't tell us anything other than you have valves. What do the valves control?
Old 11-22-18, 06:26 AM
Norm201's Avatar
Received 89 Votes on 82 Posts
This is not criticism of your abilities, but as new home owner it appears you are oblivious of basic home owner information. Not being aware of or if a home has a main water shut-off is not a good sign. You need to map all your plumbing line and valves. Make sure they are all in good working order. Shut them all off, then turn on fully, then back off about a quarter turn. Do this about every six months to keep the seals moist and in good condition. If water leaks through the stem, it needs new gland packing, if it leaks at the spout it need a new washer.
I'll also assume that you may not know your electrical system. You should map all you circuit or fuses and determine what circuit control what outlets and switches. Identify your main breaker.
Again I'm not saying you're stupid or incapable, but buy a new home is a daunting project and you should know basic things. Like where is the shut-off for water located on your front lawn.
Coming to DIY is a first good step. Good luck.
Old 11-22-18, 08:31 AM
Received 139 Votes on 124 Posts
That only works if the pipe is in a heated space, does very little if the hose bib line is in an unheated crawlspace.
Old 11-25-18, 09:41 PM
steve_gro's Avatar
In any event, it would be a very good idea to be familiar with the location of water & gas & electric shut-offs.
As far as I can tell, you don't have to worry about freezing in North Carolina. You will want your AC working in the summer.
Old 11-26-18, 06:01 AM
But it looks like a third of the state is seeing freezing temps already and its only November.
Old 11-26-18, 08:04 PM
steve_gro's Avatar
Darn... the image has changed since I posted it. Yesterday it showed NC to be completely in the temperate (no-freeze) zone. The OP has some homework to do. Although, if his area required frost-free hose bibs you'd think they would've been installed at some point.
Old 11-27-18, 06:08 AM
It really depends on where you're located in the state. The coastal areas cool much slower in the fall and often don't see freezing temps until well into December while parts of the west froze in October. But, a dripping sillcock is better than one that has been capped.
HTML code is On
